This command creates a remote endpoint.
| ipaddress | A remote endpoint IP address. |
| vr | VR/VRF instance the remote endpoint is associated with |
| vr_name | An existing VR/VRF name. |
VR-Default
This command is useful when you want to explicitly add a remote endpoint in addition to the ones learnt dynamically (OSPF extensions). In flood mode explicit, you must create a remote-endpoint using this command, if the configurations on remote-endpoint (like monitor) need to be saved to the configuration. Otherwise, the configuration will be lost after the switch reboots.
To create a remote endpoint:
create virtual-network vxlan remote-endpoint ipaddress 1.2.3.4
This command was first available in ExtremeXOS 21.1.
This command is available on all Universal switches and stacks supported in this document.
